what years can you put transmissions into
bigdade175
Post by bigdade175 »
example 67 c6 to a 90 or after certain years do they have to be computer controlled why i ask is i have a good c6 out of a 67 f100 not oringinal by the way was mated to a 302 i am looking at a 90 f100 with a possible bad tranny can they swap? let me know if anyone knows thanks 68 3/4 ton camper special /72 3/4 ton ranger
the last year the c6 was made was 86. 90 will have a computer control in it. it will probably be a aod or maybe a e4od.
AlleyCat
re: what years can you put transmissions into
Post by AlleyCat »
Craig, C6's were built into the 90's. :) I have an 89 E250 with one and I junked a 90 F350 that also had one.
Clay
i was wrong then. i was just repeating what i had read on the site i thought i remembered it correctly. oops i was wrong then.
craftsman
Post by craftsman »
First you need to know what tranny is in it. They did put the c6 in until 96. If it is a c6 it will fit, maybe some mods to the driveshaft, even if it has an aod it should be ok since the aod is not electronic.
http://en.wikipedia.org/wiki/Ford_C6_transmission
averagef250
Post by averagef250 »
No, they will not swap. The lighter F series all had the AOD and E4OD by 90. The E series vans and heavier pickups stuck with the C6 as an option well into the 90's and no, they were not computer controlled.
The EEC-IV engine trucks with C-6's had computers nearly identicle to manual transmission trucks.
