4 speed shift pattern?
evensteven13
Post by evensteven13 »
Does the pattern a truck, granny low 4 speed tell you the model? I picked up my parts truck yesterday and went to put it in reverse, all the way over and down, but it was all the way over and up. a np435? i may try to us the tech page to decode the vin and data plate. a beatiful truck that has set for 15 years in a barn, one word, dusty?
kilog55
Post by kilog55 »
shift linkage could be backwards for reverse???
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
truckguy
re: 4 speed shift pattern?
Post by truckguy »
A t18 is over and up.
Kyle
Image ImageImage
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
evensteven13
Yeap, I went outside and crayoned the data plate on the door and brought it inside, T18, 360 2bbl, 4.10 non locker, standard cab(i knew that). gas prices are horrible now. I pulled it home with my Dodge 1500 and got 8 mpg at $3.19 a gallon, I spent as much on gas as I did on the truck. The 4BT is looking better every day.
kilog55
Post by kilog55 »
did they change it in the later years cause my T18 in the 79 is over and down
Redcap
Post by Redcap »
kilog55 wrote:did they change it in the later years cause my T18 in the 79 is over and down
Yes, they did. Early T18s are over and up, later are over and down.
sideoilerfe
Post by sideoilerfe »
My 65 Camper special had a T18 and it was over and down.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
l1k2gadd
Post by l1k2gadd »
The one I found behind a 302 in a 1972 Bump is over and up.
Too many projects, too little time, but.. lovin' it!
2-1966 Mustangs (one 289-2V and one 200 6 Cylinder),
1-1990 7-Up 5.0 Mustang LX Convertible (second one),
1-1990 7-Up 5.0 Mustang LX Convertible (third one, for parts only)
1-1990 7-Up 5.0 Mustang LX Convertible (fourth one, best of the bunch).
1-1992 "FEATURE" 5.0 Mustang LX Convertible (only one)
1-1993 "FEATURE" 5.0 Mustang LX Convertible (one of the yellow ones)
cdherman
Re: re: 4 speed shift pattern?
Post by cdherman »
sideoilerfe wrote:My 65 Camper special had a T18 and it was over and down.
Then someone had either swapped it to a later T-18, or it was a NP435 and you were misinformed......
T-18s in 65 were over and UP.
sideoilerfe
T 18. It was not a np435. This truck was all original.
cdherman
Post by cdherman »
t-18 was over and up in 65. Change to over and down occured in the 70's.
sideoilerfe
you're wrong. 1965 F250 camper special 352.
1971ford
Post by 1971ford »
boss's bump is middle down lol
and first is middle up :D
-Ryan
cdherman
Post by cdherman »
I've given up arguing on web sites. For the other readers who are reading or who may ever read this thread, do your research with a couple of other sites and search a couple other sources and decide for yourself.
The t-18 tranny was an offshoot of the T-98. In fact they shared the same top cover initially, which can make things confusing with early t-18 trannies. The t-98 and the t-18 had R up and to the right. Later, the shift forks and top cover were redesinged so that R was down.
What I just wrote there is what every reputable source that I have ever read states. Arguing between the two of us is pointless.
sideoilerfe
Sometimes information on the internet is incorrect. I had a 1965 F250 Camper special 352. T18 reverse was over and down.My friends dad had a 1966 F250 with a 352 and 4speed with the same shift pattern as mine. I also test drove 2 1966 F250s that I was looking to purchase and BOTH of them also had the 4speed with the reverse over and down, period.
Another friend had a 1968 F100 with a 300 6 and a T 18 and reverse was infact over and up. My 1970 hiboy is a NP435 so we all know about those.
I'm just speaking from experience.
