I am getting a serious leak from my transmission. Is there a gasket to replace or is it something worse?
Need to replace a gasket?
Hi, I'm Nathan and I approved this message.
1968 F250 LWB 360 (now 390) 4 sp High boy mine
1999 Expedition Eddie Bauer Edition 5.4 liter girlfriend and daughters
re: Need to replace a gasket?
4 speed trans. I just pointed out the motor mount to show the drip. It is behind the oil pan and dripping on the cross member then to the ground. I felt the oil it is thin but It is not water.
- 390Nut
looks like the rear main seal might be fried. Pull the inspection cover off the bellhousing and take a look inside. Also check out the rear of the intake manifold, and the valve cover gaskets. They can leak oil onto the back of the motor which CAN get into the bellhousing, and all over around it.
At the least, take that thing to a car wash and get it clean!
Paul
`69 F100 390 4spd driver
