69 F250 360 W/C6 Trans Tranny problem
Jonboy7061
Post by Jonboy7061 »
I just purchased a 69 F250 that has set for atleast 4 years. I got it home, got it started. The transmission goes into reverse good and hard but I was only able to get it to go into a forward gear a couple of times. Once it went into a forward gear and you put it in nuetral or park, it would not go back in a forward gear. When it would go into a forward gear it went in good and solid. I check the fluid, it is good. I checked the linkage and it is good. Is there something in the valve body that could be sticking?
how did the fluid look when you checked it. was it nice and red? how did it smell? was it running when you checked the fluid?
cdeal28078
re: 69 F250 360 W/C6 Trans Tranny problem
Post by cdeal28078 »
If it is not the seals dried up you will probably need to pull the valve body and clean up all of the pistons. They will stick in their bores and not do what they are supposed to do.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Jonboy7061
Yes the fluid was red and did not smell burnt. I will remove the valve body and try to clean it and see if anything will free up. Thanks
