C6 install
OldRedFord
Post by OldRedFord »
Im confused. The "ear" on the column rotates, correct? So between that rotating somehow the rod moves back n forward to shift.
I think.
EDIT
I think what I need is calld the "bell crank assembly" and the shift rod.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Nausea
re: C6 install
Post by Nausea »
Here's mine... note the bend is less thsn fordman's and has a threaded adjuster.
'72 F250 Ranger
Disk brakes, PS/PB, 360 2bbl
Current condition : beloved 'beater'
'70 F250 Camper Special
Currently in the shop, totally stripped
mines off a dentside i think. my pic was just a representation of what it was suppose to look like.
basketcase0302
re: C6 install
Post by basketcase0302 »
Nausea,
That is different, (never seen one with the threaded end like that). All my dents looked like Fordmans, (and had no adjustment) which would be nice.
Basketcase
cdeal28078
re: C6 install
Post by cdeal28078 »
Some of the later model trucks used a bell crank set up on the automatic trannies.
Just hit the junk yards for the parts you need.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
OldRedFord
Re: re: C6 install
cdeal28078 wrote:Some of the later model trucks used a bell crank set up on the automatic trannies.
clint
So on the bumps there was no bell crank set up, just the one rod?
Hows the shifter on your C6 set up?
Tim
