Question on tranny swap 3-speed manual to C-6 automatic
MustangSteve
Post by MustangSteve »
I am changing out the trans in my F-100 2wd, 1/2T SWB 70 truck from 3-speed manual to a C-6. The tranny I have has a slip yoke type fitting in back, like a car would have, not the bolt on shaft like I see in other pics. 1st question is: Do I have to get a different crossmember for the automatic? 2nd, is there any reason I can't use the slip yoke and have a shaft built for it? 3rd: Why do I do this to myself?????????
MustangSteve
Stable includes
67 F100 SWB I-6 (trying to sell this one!)
68 F100 LWB 360 (rapidly becoming a pile of parts)
70 F100 SWB 390 (this is my "builder")
Someday all will become ONE
"Money you enjoy wasting is NOT wasted money"...
AND...
66 Mustang fastback (see www.mustangsteve.com)
66 Mustang convertible
'00 Mustang coupe
'03 Mustang convertible
'06 Chevy HHR LT2 (oops!)
re: Question on tranny swap 3-speed manual to C-6 automatic
A slip-yoke was used in 2WD short-wheelbase trucks with a one-piece driveshaft. Transmissions with a bolt-on yoke were used in LWB trucks and 4x4s, and had a two-piece driveshaft, and the slip was incorporated into the splines of the rear driveshaft section:
If the C6 has a slip yoke, you're golden. If it's got the bolt-on yoke, you're SOL...it won't work with your setup. Your truck's 3-spd SHOULD have a slip yoke driveshaft, though you'll have to shorten it to use with the C6.
The transmission crossmember is the same for all transmissions, manual or automatic.
MustangSteve
Thanks! Exatly what I needed. The tranny has a slip yoke. I either will get a used driveshaft or just have a new one custom made.
MustangSteve
Stable includes
AND...
'00 Mustang coupe
Rick
Post by Rick »
Delete Please
craftsman
Post by craftsman »
and i think the output shaft on the c6 is bigger than the one on the 3speed, so you will need a slipyoke from a c6 trans.
MustangSteve
Thanks, I figured the slip yoke thing was coming as well.
MustangSteve
Stable includes
AND...
'00 Mustang coupe
i have a slip yoke shaft if you want it. i think it is either 67 1/4 or 69 1/4 from center of ujoint to center of u joint. i think it came out of a dentside
