NPT435 Q&A
Sabbaticus
NPT435 Q&A
Post by Sabbaticus »
I have 2 questions about my tranny, and hopefully this thread will help others ask their questions as well.
1: when I shift into 3rd, I must go past the slot and pull back towards me as I go into gear or it grinds. What causes that and what will it take to fix it.
2: Where is the sensor, lead, wire, or switch located on the tranny so I can hook up the back up lights.
Thanks in advance for your help, suggestions, and advice.
:fr:
Dalton Sexton
1972 LWB 4 in floor T-18 tranny. w 360ci engine. tires 31 x 10.5 r15. F250 suspension w rear helper springs. Electronic ignition from 78 ford t-bird 400 cid. Plug wires to fit 1980 F150 460ci.
the switch is on the drivers side near the top of the trans.
Sabbaticus
fordman wrote:the switch is on the drivers side near the top of the trans.
Thanks!
Dalton Sexton
averagef250
Post by averagef250 »
Your top shift plate is worn and allowing the shifter to try and grap 1st when your going into third.
I've never seen this with 435's, but it's a very common problem with early T-18's.
Sure you don't have a T-18? Just the way the shift rails are laid out in an early T-18 makes them prone to this, your best bet is to get used to it if you have a T-18.
My427stang
Post by My427stang »
Often the shift lever itself wears and it lets the lever crooss over before its all the way out of the prior gear
I have welded up and ground many, its pretty easy fix, weld it, grind it round again, and stick it back in the hole LOL
Sabbaticus
How do I tell the difference between a T-18 and a NPT 435? It is a 4 speed. 1st is 00 you normally shift 2-4 unless pulling something heavy.
Dalton Sexton
which way is reverse? over and up or over and down?
Sabbaticus
re: NPT435 Q&A
over and up
Dalton Sexton
theskytoucher
Post by theskytoucher »
You have a t-18
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
Sabbaticus
re: NPT435 Q&A
Well I'll Be! You learn something new every day! Thank you theskytoucher!
Cough cough. :oops: Well, in the future I guess I will need to post in a T-18 thread! :lol:
Ok, is the reverse light connection going to be in the same place mentioned before?
Dalton Sexton
theskytoucher
Yes it is! And i have a t-18 also and have the problem with grinding first trying to find third!!! After awhile you just get used to driving it that way!!!
-Troy-
1976 Ford F-150 4x4
Sabbaticus
re: NPT435 Q&A
Yeah, It just stinks when you are looking for speed. I hope to fund some of the restoration by winning burnout competitions because this baby boils! But it sucks on the occasion that I can't shift smoothly. It will boil the tires through all 4 gears. I actually only miss 3rd when I am speed shifting.
Dalton Sexton
theskytoucher
Some will say you cant speed shift one of these transmissions but it can be done with a lot of practice!!!!
-Troy-
1976 Ford F-150 4x4
Sabbaticus
Yep!
theskytoucher wrote:Some will say you cant speed shift one of these transmissions but it can be done with a lot of practice!!!!
Yep, I am pretty good at it, I miss it about 20% of the time though.
Dalton Sexton
averagef250
Shifting like that is the reason why it does what it does.
Keep driving like that and you'll learn what it feels like to shift without synchros. Might even get lucky and snap a shift fork.
