Dana 60 posi carrier ID
My427stang
Post by My427stang »
I have three carriers, one of which will go into my 71 4x4 1/2 ton
I am using a 5 lug Dana 60 rear and may decide to go a different gear that I originally planned. If I can I want to use the Powerlock as its much stronger, then sell the Trac lock, but I cant really do much with either not knowing what they really fit.
From the picture below, I have a Powerlock 4 pinion posi, a Traclock 2 pinion posi, and an open diff.
When sitting on the bench, all seem a little different in where the ring gear sits. Danas use different carriers based on gear ratio groups and these parts have been mixed up under my bench since the early 80's, I have no idea what gear set was originally paired with the posi LOL
Does anyone know how to identify each carrier for its specific ratio, short of setting each one up to see how things line up?
Thanks in advance
match part number to get all the matching pieces back together with the ring and pinion. they should have numbers on them that say which one goes with what i would think.
My427stang
Nothing you see there can be considered to have ever been with another piece, consider it like a big shell game with 5-6 more R&P and carrier combos long gone over the years
This is a tiny bit of 20 yrs of stuff laying in the bench of an 8 bay garage and we moved twice BEFORE I moved away
Trying to find out casting numbers or dimension difference, its amazing, the Dana casting numbers are like secrets info or something LOL
basketcase0302
re: Dana 60 posi carrier ID
Post by basketcase0302 »
427Stang,
Try this one:
http://cgi.ebay.com/ebaymotors/DANA-60- ... dZViewItem
I've got the CD here somewhere but can't find it. :wf:
Basketcase
71PA_Highboy
Post by 71PA_Highboy »
I would look on Pirate4x4.com ... Mr. N seems to have a bunch of good stuff....
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
two-bit
Post by two-bit »
I've got a Power Lock center that doesn't look like yours.
Mine looks like a giant castle nut. Are you sure your Power Lock unit is for our vintage rear diffs?
If i remember right, the spline counts on the axles changed in '73. At least they did for Dana 70's. (Thats why its been so hard for me to find parts)
Most of the Power Lock units i did find were the newer models with the newer spline count.
You may already know this, i May be babbling for no good reason. If so....
Nevermind.
Two-bit
averagef250
Post by averagef250 »
You can sell trac-loks? I thought they were good for a few cents in scrap or an emergency use item if you toast a spider in an open diff.
There's only one carrier brake for the dana 60. If you put them side by side the ones that would position the ring gear further from the pinion are for 3.30 to 4.10's. The closer carriers fit 4.56 (and 4.10 with skinny gears) to 7.XX whatever.
In 73 Most Ford 2wd's got 30 spline axles. The 4x4's stayed with 16 spliners through 77 depending on where the truck was made.
Most Ford dana 60 powerlocks are from 1969 and earlier trucks. Ford went to the trac-o-crapper in 70 as the standard LS.
The semi-floater 60's were all 30 spline from 56 through 72.
sideoilerfe
Post by sideoilerfe »
What happened to the pic? I know it's an older thread but not that old!!!
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
heep70
Post by heep70 »
If you decide to use the Power-loc carrier in the 5 lug rearend. Make sure that there is a button on both sides in the center were the two axle slid in. They keep the axles from floating back and forth. full floating axles do not have it. I don't have a pic but you will see it looking down into the center. If not then it will be a flat surface with maybe a hole through to the other side.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
