1966 3-speed with O/D bolt on yoke, want slip yoke.
winr
Post by winr »
I have a 3-speed Tranny with T-85 O/D out of a 1966 long wheelbase 352 CI F-100.
It has a bolt on yoke, I would like to use a slip yoke, my 65 F-100 is short wheel base and I want a one piece driveshaft.
What is necessary to do this ??
Thanks.
Richard.
All your Ford are belong to us
fmartin_gila1
re: 1966 3-speed with O/D bolt on yoke, want slip yoke.
Post by fmartin_gila1 »
Don't think you can do that. You will prolly have to keep that output yoke and have a driveshaft made up with slip splines in it to accomidate the movement.
Fred
I agree, the slip-joint driveshaft would be the ticket. Since transfer cases on 4WDs don't have a slip yoke, the rear driveshaft (between the transfer case and the rearend) use a slip-joint driveshaft. If you're lucky, you could even find one meant for a SWB 2WD truck with a manual 4-speed. Here's a few graphics for the visual. The first two are shots from a SWB 4WD:
cghstrojan08
Post by cghstrojan08 »
Wow, I am always amazed with Keith's knowledge and having a picture of about everything. :bow:
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
AlleyCat
Post by AlleyCat »
Richard, I'm not sure if Ford used a 3 speed o/d with a slip yoke. I have 2 of them..One was from a bump the other from a slick.Both were short beds.Both have bolt on yokes.The bump had an FE.The slick had a Y-Block. :)
Clay
spartman
Post by spartman »
Would anybody happen to have one of those swb driveshafts like kieth has shown?
IF so PM me please.
winr
Post by winr »
Thanks for the info!!!
I would have thought that the slip joint went to the rear end joke......
That helps, I have half of a 2 piece driveshaft that had a carrier bearing.
I have the half with the slip joint on it, it has a threaded cover like in the picture.
After I rebuld my trans, I will get a drive shaft build with the slip joint in it.
spartman, I got the slip joint form a 70 or 80 something Ford truck.
It had a 2 piece driveshaft.
:fr:
Richard.
spartman
Post by spartman »
HOw long is it fully extended?
for what I am looking for it needs to be at least 69 inches long
that half shaft isnt the same as the shaft kieth is showing. it looks the similar but it wont work.
