Gear Ratios
Gear Ratios
I know I'm not the brightest light on the christmas tree, but aren't the front and back ratios supposed to match in a 4X4? My Dana has 3.54 gears and my 9inch in the back has 3.50 gears. Is this correct? The only thing i can figure is the front is a little lower gear because of the pinion size diffrence. I just don't want to lock it in for the first time and bust the ring and pinions.
- 71PA_Highboy
re: Gear Ratios
Don't worry.... those are about right...
Other ratios are 4.10 front & 4.11 rear, etc...
The difference is just so the front pulls and rather than the rear pushing... Just make sure you keep it on a surface that will allow the tires to slip a bit.
hth,
eric
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
re: Gear Ratios
Thanks Eric. I spent alot of money rebuilding those axles and didn't won't to waste it because of stupidity.
- MadMaxetc
Never thought of that. It makes sence.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- FORD428CJ
Re: Gear Ratios
As long as the gear ratios are with in 1% of each other (front and rear). You will be fine! Here is a link with good info for ya!coryb wrote:I know I'm not the brightest light on the christmas tree, but aren't the front and back ratios supposed to match in a 4X4? My Dana has 3.54 gears and my 9inch in the back has 3.50 gears. Is this correct? The only thing i can figure is the front is a little lower gear because of the pinion size diffrence. I just don't want to lock it in for the first time and bust the ring and pinions.
http://www.ringpinion.com/ContentFrame. ... ntials.inc
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
64 Falcon X-Ram 428
67 Stang 351 C/J
