T18 crossmember location
Would one of you guys that has an FE and a T18 look under your truck and tell me which set of holes your tranny crossmember is bolted into?
I am replacing my 3 speed with a T18 and I have got it bolted in and the distance from the tranny to the motor mounts seems to be close, but my driveshaft is about an inch or so short (the front shaft).
Can I even use my original driveshaft that was behind my 240 and 3 speed? Insight from you guys has gotten me this far, please don't let me down now!!!
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
- FLATBEDFORD
I have that combo in my F350, but I won't home in daylight until Thursday. I some of the ice has melted, I climb under with a tape measure. I don't know how different my F350 is from your F100.
My Photo Gallery
My Photo Gallery
re: T18 crossmember location
Thanks for the help Steve.
1989 Ford F150
1989 Ford F150
- 390Nut
With an FE/T18 combo, the crossmember gets bolted to the rear set of holes on the frame. As for the drive shaft, I wont say for sure, but it's very possible it will need to be changed.
Paul
`69 F100 390 4spd driver
Thanks Paul. I currently have it bolted in the front holes. That explains my problem I think. I think I can reuse my original driveshaft if I move the crossmember back. I'll give it a try.
And the engine perchs bolt into the rear holes as well, right?
1989 Ford F150
1989 Ford F150
- FLATBEDFORD
Does this mean I don't have to climb under my truck in the ice now?
My Photo Gallery
My Photo Gallery
Steve, you're off the hook. Thanks for the offer though.
1989 Ford F150
1989 Ford F150
Got the crossmember moved and the driveshafts from my original 3.03 and 240 bolted right up. Sweet!
1989 Ford F150
1989 Ford F150
