I will be rebuilding the front end of my truck in the near future. The radius arm bushings are mush, however I don't see any play in the king pins. Would it be ok to go ahead and disassemble the king pins and replace the bearings, then assemble the pins as they were? Is it possible to do so?
I would just leave the pins alone if it weren't for the thought that the bearings may be bad. Has anyone dealt with this before?
axle rebuild, 69 Camper Special
