transmission swap, standard to auto
- thebannister8
hi all. i have a 67 f100. i'm thinking of changing the standard 3 on the tree ( now on the floor ). to an auto trans. was the c4 the stock one in 67's. and can a c4 auto plug right on. thanks. steve
re: transmission swap, standard to auto
A C6 came in our trucks. A C4 is more of a car trans. What engine do you got?
Kyle
Kyle
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
I didn't know that.
Kyle
Kyle
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
- thebannister8
Be cool to find out.fordman wrote:i think the c4 did come in the 67. maybe with the six attahced to it.
A C6 would go behind it. A C6 is more of a truck trans.
Kyle
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
- thebannister8
Cool, but I bet its not stock. Its has to be built up some.
One way to try it and put it in and see what happens. Good deal.
Kyle
Kyle
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
- thebannister8
you also have to watch out which tailhousing it has on it. if it has a long tailshaft it is for a car or slip joint driveshaft. if its short then its a truck or bolt on yoke type of tail housing. you need the one to match your drive shaft. or get your driveshaft remade. you may also have to shorten your shaft anyway depending on several things i dont know about your truck.
- thebannister8
hope it goes good.
Kyle
Kyle
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
