AOD Transmission & FE Engines
- Finleyphoto
Just need a quick recap.
Will an AOD transmission work with a FE Engine? And if not, why not?
I'm on the job and don't have time to research it with the dial-up.
Thanks - Dennis
Thanks - Dennis
re: AOD Transmission & FE Engines
It isn't a straight bolt up, but there are a few adapters out there, and I believe there is even a company that cuts the OE bellhousing off and bolts on a new one...
I'll try to come up with links in a little while...
- MaxKlinger
Anything's possible with money. I think there's a company that makes an adaptor but that sort of thing is usually expensive. The AOD transmission was mediocre at best, not known for its reliability. Good luck.
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
Links:
http://www.transmissioncenter.org/ (scroll about 2/3rds of the way down the page.)
http://www.supermotors.net/vehicles/registry/10/31182
Legendary ford also did an article on:
Bristol Services Company Gary Croan
711 W 17th St
Costa Mesa, CA 92627
Tel. +1 949.722.1122
I believe that he is the one that grafts a new bellhousing on.
I seem to recall that PA made a bellhousing for conversion but can't find it on their website, perhaps I'm thinking of a C4.
I expect you can plan on spending 2000-3000 by the time you get it adapted an built to stand up to the power.
I think it would make a nice package though.
711 W 17th St
Reliability in a AOD is all in the set up ! I have one in my bump side but its behind a 302. Can't say I've ever seen a FE with a AOD though. And if your throw money around, just use a C4 or C6 with Gear vender behind it. It'll only run about 2-4k dollars
- Vinniesempire
- Vinniesempire
It's a small block trans. Won't last long. 3rd and 4th will blow out.
How long its going to last all depends on how well you build it and what parts you use. I know 500hp cars and trucks that run a aod. One thing you will have problems with is exhaust. My long tubes on my 302 lay against the aod on the passager side. So you would have to run stock manifolds or mod. the headers.
- binder56jd
gearvendors is the only sure fix
now serving #235
now serving #235
Wow you guys really believe in those FE engines. I have only had 1 390, but quite a few 360s. They were one weak engine for how much they weigh. I love my old Fords but the only FE V8s worth talking about were the 406/410/427/428s 360/390s were a big waste of time in the pickups. Poor fuel economy and NO power. I think an AOD built well would outlast several 360s maybe even a 390.
Only reason to keep an FE in your truck is to keep it stock for purists/show. A 460 stock will run circles around a 360/390 .
I even considered pulling the original 360 2V(rebuilt right)out of the Merc and building a 460 so we could actually use it for something other than trying to drag it's lazy ass around to shows/cruise nites.
The FE has a very stout block and thats about it.
OK maybe a 427 SOHC is good . But ?????????
Collecting 67-72 Ford/Mercury trucks since 1980, collecting 73-79s since 1990 when the 67-72s started drying up. Now I'm culling the herd. None of my 67-72 will ever be for sale! They will need a big hole in the ground.
Re: re: AOD Transmission & FE Engines
I strongly disagree...68Mercury250Ranger wrote:Only reason to keep an FE in your truck is to keep it stock for purists/show. A 460 stock will run circles around a 360/390 .
- binder56jd
ain't this place great
both sides of the fence--for sure--and both r Ford--luv it
now serving #235
now serving #235
Hey nobody is wrong. Some are just more right.
Seriously I would love to put another FE in my 68 Merc, but it sure wouldn't be a 360 or 390. I'm still watching for an old 410 or a 428.
I missed out on a couple basket case 427SOHC motors that came with enough extra parts to complete almost 3 engines. Oh yeah that was over 20 yrs ago.
This place is a wealth of information .
- ford7379trucks
you can get a moded aod that bolt up to a fe for $1,500 ill look for the link. the stock aod will fail but u can rebuild them to handel 1000hp
1967 F-250 CS(starts every time)
1998 jeep grand cherokee(pos)( glad i got the 67 to save my a**)
1982 Suzuki GS1100G zero to stupid in nothin flat
