I was sitting here tonight surfing Ebay for cool truck parts, and there was an auction for a chrome cargo light, which the seller mentioned has some pitting. This led me to think about some of the chrome trim going back on my truck which has some semi-minor pitting....mainly the hood emblems, cargo light housing and body insignias.
Anyway, I was wondering if anyone has taken a Dremel tool to their pitted pieces and was able to clean them up enough to be presentable. I know, I should just give it a try, but I just thought I'd start a thread pertaining to this, since I know virtually everyone out there has the same problem. If you were doing a full restoration, you'd obviously spring for NOS or repops, but many of us fixing up daily drivers (or weekend cruisers) either can't afford or can't justify the expense, so I was just wondering how feasible it would be to attempt to gently grind down the pits so they weren't as obvious. Once the pits ARE ground down, do the damaged areas need to be sealed somehow, and if so, with what?
Chrome pitting - can it be fixed?
re: Chrome pitting - can it be fixed?
Me and my dad did this expierement with some rubbing compound and a dremel tool on some "Custom" trim pieces I pulled from the boneyard. If the pitting is very light it will take it out and clean it up nicely but it didn't seem to work real good for the heavier stuff. If i remember Ill try and post a pic.
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
- rjewkes
i know steel wool like you might use in the [censored] on your iron skillet works wonders just keep it wet or you'll supper heat what chrome is there.
I know this method has removed surface rust from the lower body chrome on my '72 ranger xlt and they look better than they did.
Only othewr way i have seen is to do like many do once it is pitted they use a good filler putty and then smooth it out and paint it to match body or go black with it. I don't know how well this will work on the hood emblems.
i suppose after you remove the pitting somewhat you could hit it with clear to make it shine and protect it could that be a course of viable action?
fuelly.com
fuelly.com
