High Clutch Pedal
- edselehr
High Clutch Pedal
Sorry...I have another '77 F250 question...
I bought this truck in June from the original owner. 300 six with NP435 four-speed. The clutch pedal sits a LOT higher than the brake, and requires a lot of leg motion to engage it. I just bought a shop manual set and glanced at the clutch adjustment section - not sure if I understand what kind of adjustment is in the clutch. The upper limit of the pedal seems to be set by the rubber bumper underneath the dash - perhaps this is worn or broken?
Anyway, any advice would be helpful.
- heep70
re: High Clutch Pedal
They are all that way.
Just don't bump your chin when you lift your leg that high.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 19674x4
yup. the clutch is set high. its just that way. and its hard to push because its a spring and fork and not a hydraulic clutch.
My Photo Album
- MadMaxetc
Yep...just that way.
You will get used to it.
I actualy think new cars feel wierd...cant "feel" the clutch and they are too touchy. (I do like the 90's mustangs, they fell right.)
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- averagef250
Actually, a lot of these trucks have had the rubber bumper rot and fall off over the years. This adds about an inch to pedal height.
Every truck has a slightly different clutch feel to it. If you lube everything up, make sure bushings are where they're suppose to be, the right springs are in the right spots and adjust the freeplay correctly the pedal should be nice and easy with a good diaphram clutch.
- Ranchero50
Yep, what Dustin says. Also you can loosen the pin that that bushing is on and adjust it to lower the pedal. I had to raise mine a little for complete clutch actuation on the diesel swap.
Jamie
Jamie
- edselehr
Thanks everyone...that's what I was kinda thinking was the deal.
But the clutch feels just a tad too high, and I've looked under the dash and the rubber bumper seems thin, so if I can replace that and gain about an inch in dropped height, that will make a world of difference.
Put some heater hose over the stop pin. Works
That stop has an eccentric bolt. In other words it is off-set to allow you to adjust the peddle height. Works well as long as the rubber bushing is still there
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
the 73-79 brake pedals are lower then the 65-72.
The 73-79 clutch pedals are VERY high and have a very strong 1-1/2 diameter clutch assist spring on the pedal. it is not uncommon for this spring to break and fallout at some point. without this spring the clutch works fine but will have a much harder feel and take more effort to press.
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
69 F100 300-4spd
78 F150 300-3spdOD
- basketcase0302
edselehr,
You might want to make sure that one inch you're gonna add won't affect the clutch. Try holding it there, (depressed the one inch) to make sure it's not already engaging the clutch. Otherwise, you'd be riding the clutch and wear it out faster.
Basketcase
Basketcase
