69 tranny fluid change?
04stangman
Post by 04stangman »
Is it this easy?
1- drop the pan and let the fluid drain out.
2- clean off pan and tranny.
3- put some gasket sealer and a new gasket on....
4 replace bolts............
Or am I missing something? I am really new to this old truck stuff, and you all seem to really know your stuff! I need all the help I can get. Should I let a shop do the fluid change............. Or is it something a guy like me with little skills can accomplish? Thanks for any help I can get!
Finleyphoto
re: 69 tranny fluid change?
Post by Finleyphoto »
Change the filter or screen.
Dennis
basketcase0302
Post by basketcase0302 »
04stangman,
What tranny model?
Some fords had a ball bearing, (I believe some kind of check valve) above the filter. When you dropped the filter it came out, (don't lose it if you have this). :cry:
Some of Ford's four-wheel drive C-4's also had a short tube/pipe that ran through the filter, (if you got it make sure you put it back in).
Definately change the filter for sure.
Hope this helps.
Basketcase
truckguy
Post by truckguy »
I wouldn't use gasket sealer, go out and buy a good gasket(not the cork stuff) and you not need sealer. With a good gasket the bolt holes hold some of the bolt so you can hold the pan and put them in. So what basketcase said be careful when pulling out the filter.
Kyle
Image ImageImage
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
04stangman
Re: re: 69 tranny fluid change?
basketcase0302 wrote:04stangman,
What tranny model?
Hope this helps.
Basketcase
Supposedly I have the C-6, thats what came stock. Hum, Now I am not sure if I want to try it my self?
truckguy
Post by truckguy »
Its not hard to do. I think that you can to it. Is there something wrong with the fluid or just wanting to change it.
Kyle
Image ImageImage
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
truckguy
Post by truckguy »
I see, are the bolts lose. I check that first and if not, then it needs a gasket.
Kyle
Image ImageImage
1986 F-150 300
1970 F-350 360 PB
1968 F-350 360 PB
1968 f-250 360 PB
basketcase0302
04stangman,
Not really that hard to do, (sorry, I didn't mean for it to sound like it was).:doh:
If you can afford it, a nice thing for the future is one of these.
If your pan is leaking around the bolts, chances are someone has over-torqued the bolts and distorted the flange/lip of the pan.
It sucks to get the pan off and find it's not flat anymore, (yeah, you can peen it flat again but take a chance on it still leaking)?
Basketcase
04stangman
Thanks Guys for the help, its nice to know there is still a place we can go to get help with these old bad boys!
you will also want to drain the toruqe converter to do a full fluid change. the converter has a square bolt in the front of it to drain it.
04stangman
fordman wrote:you will also want to drain the toruqe converter to do a full fluid change. the converter has a square bolt in the front of it to drain it.
:? Do you have a picture or directions to this part? I have no idea what that is?
under the truck. on the front of the trans is a plate made of tin remove that. inside there is the converter. spin the engine by hand or with a screwdriver on the teeth. youll see them. until the square headed bolt comes into view. remove that and fluid will flow.
69rangerman
Post by 69rangerman »
If the pan is warped you can get a large 8-10 inch file and flatten it back out if it's not too bad. While it's out, go and buy a 1.50 drain plug and install it by drilling a hole in the deep part of the pan (make sure it won't hit anything when you re-install the pan). It makes future drains a snap.
:fr:
Here's a shot of the torque converter drain on the C6 behind my 460. It'll look similar to this:
I took this shot when I was documenting removal of the rounded-off flexplate nut....that's why it's all boogered-up.
