Carrier Color?
BobbyFord
Carrier Color?
Post by BobbyFord »
Anyone know what the carriers are painted with stock?
I've got my truck all apart and I'm sandblasting the leafs, diff housing, brackets, etc. and prepping everything for paint.
the frames were all the same color and everything attached to them such as the carrier bearing and the tire carrier
BobbyFord
Post by BobbyFord »
fordman wrote:the frames were all the same color and everything attached to them such as the carrier bearing and the tire carrier
Not the frame, the diff pumpkin. Stock, they are a reddish, rust color.
I don't know if it's special paint or what.
BobbyFord
Post by BobbyFord »
O.K., how about the stuff they use on internal parts of electric motors? What's that stuff called?
Some people use it for engine valleys and cylinder heads.
71PA_Highboy
re: Carrier Color?
Post by 71PA_Highboy »
Actually it is Red Oxide Primer....
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
seattle67
re: Carrier Color?
Post by seattle67 »
Bobbyford,
are you thinking of Glyptol?
Dan
averagef250
Post by averagef250 »
The underside of the body from the base of the firewall back (the entire underside of the bed included) and the rear diff center are red oxide primer on our trucks.
That's of coarse assuming you have a 9 inch rear. Dana axles were chassis black.
BobbyFord
Post by BobbyFord »
O.K., I guess it's red oxide primer.
Is the Glyptol more durable? My dad painted the inside of his 466 with it.
