![Confused :?](./images/smilies/icon_confused.gif)
oil pan
oil pan
i have a 72 short bed i am swapping a 6cyl over to a 87 H.O. 302 can i use the rear sump pan or do i have to change over to a front sump and will i have to change my motor mount towers ![Confused :?](./images/smilies/icon_confused.gif)
- wt4speed#2
re: oil pan
Hey Good luck
I'm doing about the same swap ,except with an unidentified BB , the towers for I-6 and fe motors are the same, but the 302's are not interchangeable , the engine stands for the 302's are out there and you might look at several before find a set that haven't been cut on
As for the oil pan my motor was out of a supercharged '85 stang kid bought it for the supercharger and scraped the bulk of it ,I end up with what turns out to be a '87 truck block 302 but it has the mustang pan I think either will work
The block is bored .30 over, roller lifters and rockers , heads turned out to be "66" series289 heads ported and polished intake and exhaust ,domed cylinders and stainless intake valves
Keith put to get a tech page on the engine stands when i posed this question
Tony B
Tony B
