Check with the skytoucher he had a complete setup for the f250 ready to go hes in AZ.oldbiker wrote:OK, I went to junkyard, they have everything I need to to do disk brake conversion..I need it for 1/2 ton & 3/4 ton..Will be off of vans..This guy is a horse trader..what is this worth.. I need a ball park idea.. he has enough that rotors will be good... gonna rebuild calipers. I will go through all the threads to get a complete list of what I need. I know that is in here, I think I remember a tutorial as well.. I need to know what y'all think they would be worth if I pull them and what it is worth if he does.. Thanks gents![]()
Yup and I have enough cans open alreadycustomcrewcab wrote:i am just glad you read it and found out the info. i wasn't 100 percent sure and even pm keith and ask him but didn't hear back. i just remember avergef250 say somthing about a van he had and changing the steering box and he used one out of a truck. said it turned left when he turned right. i guess if you got the steering box you could make it work but then just opens another can of worms.
Thanks binder, I read them bout 1:00 this morning...I did a search it turned up 26 threads and those were in one of them.. It might have been because it was in the middle of the night that I got so confused. The best thread for me was flatbedfords...all made perfect logic to me till the end of it. 6 new wheels for $50binder56jd wrote:oldbiker here r links 2 tec articles by Keith
http://www.fordification.com/Ibeams&spindles.htm
http://www.fordification.com/discbrakes01.htm
cool sites flyboyflyboy2610 wrote:If you are doing the discs on an F250, you do NOT need to change spindles, The spindles are the same on drum and disc trucks. Find a set of dual caliper spindles and remove the caliper bracket and backing plate. They will bolt right on to your drum brake spindles. Then get the rebuilt calipers, and new discs and bearings/seals. You wil probably have to go to a salvage yard to get the proportioning valve.
You can look for dual caliper disc brake spindles here:
http://car-part.com/
Rock Auto sells the calipers.
http://www.rockauto.com/
Good luck!
