Transmission swap
rs2600
Transmission swap
Post by rs2600 »
I have a -70 4x4 F100 with a 390/manual 4speed. What parts are needed to change over to an automatic?
/Mat
Redcap
re: Transmission swap
Post by Redcap »
Transmission, torque converter, flexplate...kickdown and related hardware for the carb, trans cooler. Probably a couple things I missed, too...
rs2600
Post by rs2600 »
So I can use the old transferbox and just get a 4x4 auto trans + some other small details or can I use any truck trans?
/Mat
you'll also need a shifter either on the column or through the floor. it will have to be from a 4x4 because the tail shaft is short on the 4x4 versions of the auto transmissions.
MaxKlinger
Post by MaxKlinger »
fordman wrote:you'll also need a shifter either on the column or through the floor. it will have to be from a 4x4 because the tail shaft is short on the 4x4 versions of the auto transmissions.
Ratcheting floor shifter would be easiest, I would think.
rs2600,
I'm just curious why you would want to swtich to an automatic from a standard. I belong to a lot of forums, import and domestic, passenger cars and trucks, and everyone's always trying to convert automatics to manuals. About 5 years ago a buddy and I did a trans swap on his Dentside SWB 4x4, and we pulled out the C6 in favor of an NP435. Actually pretty easy to do. He left the column shifter in there just to confuse people. :D
If you prefer an automatic and go through with this, enjoy. You should make your truck the way you like it. But there are a lot of people who search hard to find manual transmissions because they believe them to be better. You may want to rethink this if you can.
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
averagef250
Post by averagef250 »
No, your t-case won't fit an auto. You need to find a C-6 and 205 t-case from a 73-79 F-100 4x4.
rs2600
Post by rs2600 »
One of the biggest reasons why I want to change to an automatic is that I'm to old and lazy to shift and I don't like stickshift with big engines and I espcially don't like the truck trans. Since I'm not doing any off-road driving, just cruising around town, the driving will be a lot more comfortable with an automatic. Biggest problem with the conversion is that there are no parts available in Sweden. I have to send for them from the states. Therefore it is important that I get info on ALL the parts needed to change over. What I do know I need is a shifter, kickdown kinkage, flexplate, converter and a C6 with matching t-case. Anything else?
/Mat
