Axle pivot and Radius Arm
1970FordTK
Post by 1970FordTK »
I will be soon replacing these bushings, I would like to know what the torque for those bolts will be for when I put them back. Thanks. :)
MadMaxetc
Post by MadMaxetc »
realy tight. I couldn't find a spec, so I did 150ft-lbs...ie me standing on a 1' breaker bar. :D
Dan
FORD Girl
Photobucket Pictures
72stepside
re: Axle pivot and Radius Arm
Post by 72stepside »
:yt:
Plenty tight will do. There should be a safety cotter pin there anyway to keep the nut from completely falling off. You make it plenty tight with a standart ratchet or breaker bar and it'll be there for a while.
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
MadMaxetc
Post by MadMaxetc »
I was talking about the Radous Arm to Axle Bolt. The Radous are bushing Net should be Tight (75ft-lbs??) and a Cotter pin to make sure it doesn't come off.
Dan
FORD Girl
1970FordTK
Thanks guys, as a digit head I'm use to having to follow spec numbers for everything. :D
ima71 trucks are older
Post by ima71 trucks are older »
I seem to remember it was around 275ft/lbs
I did it a couple years ago and needed a 3/4" drive torque wrench. Its also a 1 piece steel lock nut. the bolt is reusable but get a new nut. any GOOD hardware store or any bolt shop will have the nuts.
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
