Installing Grant wheel...
I am currently installing a Grant wheel on my Ps auto column for the ps conversion I am doing.
I had to pick up a new turn signal lever, and install a new turn signal cam, which is already installed now. I am wondering what makes the cam cancel itself? Like when you have the blinker on and and you go around a corner and it turns itself off? I am afraid I am missing something, but dont know what.
Any help would be apreaciated, thanks!
- studdmstr
I'm using the grant billet adapter and there is a pin that goes in a hole in the grant adapter facing the turn signal switch which works similar to the original. Mine was a brass looking pin. I took the pin off mine because it kept catching the turn signal cam wrong and breaking the ears off the switch.
Hmmm, definitly dont have that part. This sucks, back to the junkyard I guess.
On a lighter note, the column just came out of the paint booth, and looks sweet. Painted 'er Medium gray metallic, gonna two tone the whole interior with semi gloss black.
Thanks for the heads up, I will yank a wheel at the junkyard tomorrow.
- theskytoucher
re: Installing Grant wheel...
You have to buy the steering whell install kit in order to mount the steering wheel, in the kit it will have a roll pin that cancels the turn signal! I think the kit is like 20 bucks from autozone!!!! it comes with everything you need!!!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- jzjames
The stock wheel should have the pin thing which just pulls off and then can be pushed onto the grant wheel hub
This is what the factory piece looks like.
It snaps onto the bottom of the steering wheel hub. Sorry for the bad pic, it's the only one I had:
