4 wire tach wiring
- rjewkes
4 wire tach wiring
help i bought tach but it did not come with instructs, green wire goes to somerwhere in engine bay red must be power, white ??? Black???ground??? and what does the green wire wire to? Help
- Old70F250
re: 4 wire tach wiring
Green, negative side of the coil; Red is a fused power source; Black, is ground; and White goes to the lighting circuit.
- rjewkes
ok but under the dash what in the light switch plug is the dash lights?
and i checked my fuse box no male or femal openings next to the lamps.
- Joshpow
I dont know which wire is the interior lights off the sitch, but I always use a fuse tap to come off the side of the cluster light fuse. This allows the wire to be fused by that fuse as wel as allowing for the light in the tach to dim and brighten with the cluster lights. I dont know if that helps or not, but I hope it does.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- rjewkes
ok what is a fuse tap?
- rjewkes
and WOE do you get one?
- roachrider
I usually just take some thin metal and cut a strip about 1/16" x 1/2". I bend it in a V and solder the wire to it. Then, remove the fuse, and put one of the leads in the V and push the fuse back in. Make sure you put the connection "after" the current passes through the fuse. If that didn't make sense, I can post a picture of it. Let me know.
Thanks,
-Aaron Taylor aka...Mr. Winch
1967 F-250 HiBoy - 352ci, NP-435, Dana 24, Dana 44 & 60, 4.56's, Riding on BFG 35's
1982 KZ-1300 - 650 pounds, 120+ HP, 85 MPH Speedo
- rjewkes
for all intents and purposes lets have a look at the pick please i think you mean the passenger side of my fuse panel but i'm more visual than anything else thanks so far, how are you doing today?
