'67 vs '72 differences
My Twin brother had his '67 (built in August of '67, number 215 out of Norfolk... fairly early truck I would say!) at my house the last couple of days. We noticed his heater control knobs are different than what's shown on the site (not like any shown). Also compared stuff to my '72. The underside of the hood is different. There are these brackets and rubber pads at the cowl to align the hood when it's closed (mine doesn't have these). The stone deflector is different (not just holes drilled for the marker lights as shown here, but shaped different below the marker lights). The rear upper shock mounts are different. He has adjustable steering stops on the front suspension. I'm sure there is more. Just curious if other '67s have this stuff?
1969 F100 Ranger LWB Big Block, factory bucket seats and behind seat storage (arrived 3/21/12) (and it was free!)
1986 Thunderbird Turbo Coupe 247K and still going strong! (sold with 251,758 miles on it!)
1986 Comp Prep SVO Mustang (1 of 83) "the original Fox body "R" model!!"
1972 Ford F-100 LWB SOLD 5/2/6
1995 F150 XLT Supercab (wanna trade for a Bump?)
re: '67 vs '72 differences
In regards to the hood bumpers, read THIS THREAD. It appears that this was an '67 thru early-'68 feature.
My '67 F100 didn't have an adjustable steering bumpstop...just a solid pin, but the '67 F250 I parted out did. These are the only '67s I've had access to, so I can't vouge for any others. It wouldn't be hard to drive the pin out, thread the hole and thread in a bolt and jam nut to make it adjustable.
As for the heater controls, you didn't mention what was different, but trucks with the basic heater didn't have the three controls below the radio, but instead had a single control below the instrument panel. (I should probably add that part to the ID page.)
I've never heard of the rear shock mount differences...can you post a pic? I'd be interested in seeing how they differ.
Next time he's here we'll take some comparison pics.
- SVT522
My truck was built in August of 1966...I think Kraig fat fingered that! My truck is a Custom Cab...I'm not sure if that affects the heater controls or not. We noticed a few other differences. I retire from the USAF in June. When I move home we'll definitely take some pictures of the differences we find.
SVT522
ASE Master Automotive & Medium/Heavy Truck Technician
"The Speed Bump" 1967 F100 - 466 "Cobrajet", C-6 trans, 4.11 Detroit Locker
1969 F100 4x4 - 360, NP435, Dana 21
1973 Mach1 - 351 CJ, C-6, 9-Inch
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
Well, I beat you to the punch! I was at the shop today doing some cleaning and had the digital camera with me, so I got some good side-by-side comparison shots of the valance panels and hoods.
First of all, l have to thank you for bringing this to our attention. After comparing the valance panels, I find that there really is a BIG difference between them. To begin with:
CLICK TO ENLARGE
Here's a shot of the turn signal area between the two. The '67 panel is on top, a '70 panel is on bottom. The '70-'72 had wider turn signal indicators, therefore the notch for them is 1-1/4" wider than the '67-'69 panels. Therefore, this means that the early panels will NOT work on a later truck...the turn signals wouldn't fit. You CAN use the later panels on an early truck, but there will be a 1-1/4" gap alongside the turn signal indicator.
CLICK TO ENLARGE
Here's a shot of the valance panels' frame notch. It's almost not even noticeable, but the '70-'72 panels' notch is 1/4" wider than the '67-'69 panels.
CLICK TO ENLARGE
It's also not very apparent in this picture, but the edges on the '67-'69 panels are much sharper than the '70-'72 panels. The later panels' edges are much softer (more curved). This really isn't critical unless you're trying to do a 100%-correct restoration...but just thought it worth mentioning.
Just for future reference, I just updated Page 2 of the Identifying 1967-1972 Ford Pickups tutorial with this info and these pictures.
CLICK TO ENLARGE
CLICK TO ENLARGE
CLICK TO ENLARGE
Last edited by FORDification on Mon Apr 25, 2005 12:40 am, edited 1 time in total.
OK, here are the differences in the hoods (and yes, this info and these pictures have also been added to Page 2 of the ID page.) The hoods' outer skins appear to be identical thoughout all the '67-'72 trucks, but the inner bracing is a little different on the '67s.
CLICK TO ENLARGE
The '68-up hoods' bracing had an additional hole that the '67s didn't have.
CLICK TO ENLARGE
In addition, the side bracing is very slightly different, with the '68-up hoods having additional supports.
CLICK TO ENLARGE
Also, '67 and early-'68 hoods had a small hood support bracket with a rubber pad which bolted to the firewall and supported the rear part of the hood. Late-'68 and up hoods didn't have this bracket, but an additional rubber bumper was added to the trailing edge of the hood.
CLICK TO ENLARGE
CLICK TO ENLARGE
CLICK TO ENLARGE
My hoods aren't like any you picture here, there are no holes along the sides of the inner part.
Oh really? Hmm....well, you're DEFINITELY gonna have to send some pics now!
- SVT522
My '67 shocks have "eyes" on both ends and Kraig's '72 has an "eye" on the bottom and a stud on the top like the front shocks do.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- 67F250CS
Dont forget these may be an aftermarket replacement and not factory at all. My front fenders were aftermarket and made much thinner than factory. They have been replaced with Henry's originals.
1967 F250 Camper Special
I seriously doubt the hood has ever been changed...and if it was, what are the odds the spare I got with the truck is an identical aftermarket part (for that matter, if he had the spare why would he bother buying an aftermarket hood?)? I'll try to get some pics of both of them.
- mk
Not sure if this has been discussed but here's another difference- the cabs from 67-71 had the shoulder belt mount near the back window in the corners. At the start of 72 production, these holes were moved forward three or four inches.
mike
mike
Actually that HAS come up before...I just haven't gotten around to posting some pics on the ID page yet. Thanks for reminding me.
