driveshaft jackassery
- bobbyinpd
Today I changed the Carrier Support Bearing on my bump. Got the front drive shaft all back together and in, but I cannot get the rear shaft to engage back on to the splines of the front shaft. Its driving me nuts as to why, I have done the same thing on my 58 bel air's 2 pieced drive shaft, but have never encountered this problem before. Any suggestions?
1996 F350 4 Door Dually Long Bed Power Stroke Diesel - K&N FIPK Intake, MBRP 4" Straight Exhaust, Diesel Turbo Lifesaver Turbo Timer, BriteBox.
1990 Escort 1.9L Stock
1958 Bel Air 4 door - FOR SALE
1975ish Camaro Autocross Car
1973 Camaro RS awaiting cage,backhalf, and 498 BBC
1969 El Camino - Wife's car
2004 Carson Trailer-to haul the goods!
www.bobby77.com
www.bobby77.com
- cooltoolguy
re: driveshaft jackassery
grease it
72 Ford F-350, 2WD, 4 speed 360, Dump truck
76 Ford F-350, 2WD, Cab and Chassis <--gone
- bobbyinpd
Already thoroughly lubricated. I always lube it up before I stick it in!
www.bobby77.com
www.bobby77.com
- adrianspeeder
Re: re: driveshaft jackassery
And that's what she said.bobbyinpd wrote:Already thoroughly lubricated. I always lube it up before I stick it in!
Then the bed broke...
Sorry I don't have an answer for ya, but that cracked me up fer about a minute.
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
- averagef250
- bobbyinpd
Ok I've tried filing the splines a bit, still nothing, I'm actually considering Averagef250's Idea. I jus want to get it done so I can drive my truck, i'm sick of the suburban
www.bobby77.com
www.bobby77.com
- heep70
Is there one spline thicker then the others? Keeps the balance of the shaft inline if takin apart. can't remember if they did this with Fords. Check anyway.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- jbanks
Yes, look for a bigger spline that needs to be lined up. Make sure it's on both ends. If it's on one and no the other it might not work.
- bobbyinpd
I got that figured out for the balance. I remember reading on here that the u joints should all be in line for balance. I have gotten it to go back together, but had to do it outside the truck so i wouldn't go insane. I should lube it up a bit more than slide it in deeper
www.bobby77.com
www.bobby77.com
Thats what she said.
- bobbyinpd
Got it in today!! Thanks for your help boys, lubed it up and tapped it a bit and it slid right itn!!! You guys are great and
www.bobby77.com
www.bobby77.com
