curious........
crash_552
curious........
Post by crash_552 »
The vin on my truck says the factory rear end was a Dana 60 4:10.
But a couple years after I bought it, a bearing went out in the pumpkin and the axle walked itself out. That was a fun ride. Anyways, I grabbed what was left of the bearing and took it to Gopher Bearing. They could not find a replacement, and if they can't match, cross-reference, or find one--nobody makes it. They had it for a week. Now is this normal or what rear end could it have been to be that obsolete? No I don't have it, I swapped a junk yard for a different working rear end.
REDNECKMOBILE
re: curious........
Post by REDNECKMOBILE »
A Dana 60 does not have a "pumpkin" in my terminology. Does your truck have 8 lug wheels or 5 lug? My guess is you have a 9" Ford that is standard in the 1/2 ton versions, the Dana 60 was used in the 3/4 ton versions. Maybe yours has been converted sometime through the years, a couple of pictures of the rear would help. JMO.
ToughOldFord
re: curious........
Post by ToughOldFord »
Yes, something doesn't compute, the D-60's axle shafts aren't held in by a bearing.
crash_552
re: curious........
Post by crash_552 »
I don't have the rear end anymore, I had to swap it out. But it did have 8 lugs cause my tires went right back on the newer rear end. A better description would be that when you jacked it up and pulled on the tire the axle came with. And it was because of a bearing. I just wanted to know if anyone else ever heard of that before.
gmcjimmy88
re: curious........
Post by gmcjimmy88 »
I am not sure if any axles are held in by the bearings. A c-clip would be more likely. I also cannot think of any axle being that obsolete that parts cannot be found. Something doesn't add up in my opinion. Do you rebember what the pumpkin looked like?
crash_552
re: curious........
Post by crash_552 »
:oops!: it was on the floater axle and the bearing was discontinued, i probly could have found one if i looked hard enough but at the time it was quicker and easier to put a new rear end in.---there wasn't wasn't much left of it
ToughOldFord
re: curious........
On semi-floaters the axle shaft is held on by the bearing which is pressed onto the axle shaft behind the hub. IE the ford 9" used in half tons.
On a full-floater the hub is bolted to a spindle on the axle housing and then the axle shaft is bolted to the hub/drum assembly. IE the Dana 60 on the 3/4 and 1 tons.
But here's an odd I've only come across once:
A friend of mine had a '88 F-250 Super Cab Diesel 2WD and it had a semi-floating 8 lug rear with outboard drums on it!
At the time I had almst the identical truck, '84 F-250 Super Cab Diesel 2WD and it had the usual full-floating Dana 60 on it. I've never figured out what rear end he had and why it was on there. :dk: Maybe someone here can clue me in, I'd forgotten about it 'till I read this thread.
So your old axle had the large center hub on it?
averagef250
Post by averagef250 »
He had a semi-float sterling rear. They're very common under the lighter duty 3/4 ton 2wd trucks in the mid to late 80's.
ToughOldFord
re: curious........
I wonder what genius @ Ford thought a 3/4 ton diesel was a light duty truck? :lol:
averagef250
Ford was better than the others in that time frame. You had to get a heavy 3/4 or 1 ton chevy to even hope to have the chance at getting a full floater. The 9.5" chev semi-floater is a pile of junk too. Atleast the semi-float sterling that Ford used was a pretty good axle.
19674x4
Post by 19674x4 »
Applied industries has a good bearing selection. that 's where i get all my wheel bearings, and bearings for my d-60 and d-44
My Photo Album
