CrewCab Roof Question
Ford_Doctor
Post by Ford_Doctor »
If you look at the pic in the link you can see that there is a large gap between the roof panel and headliner support. There has been some damage to my roof and need to know if this gap is normal. It may be hard to see in the pic but the gap is about 1-1/2".
http://www.fordification.com/galleries/ ... r-Roof.jpg
MAK
Location: Georgia, Blairsville - Florida, Flagler Beach
re: CrewCab Roof Question
Post by MAK »
I just pulled the headliner out of mine last night. If that is the support that runs right down the center from front to back then there is no gap on my 72. It runs right up agains the roof panel and seems to have a thin body seam caulk or something sandwiched in between in spots.
Just noticed yours is a crew cab and mine is not. Don't know if there is a difference...
Ford_Doctor
On the CrewCab there is the one you are talking about going from the rear view mirror area but it tees into a crossmember going from B-pillar (between front and rear doors) to B-pillar. And finally the third goes from about center of the rear door to the other rear door. The roof dosen't touch these supports anywhere, but the greatest gap (in center) is the 1-1/2". BTW the pic was taken from the right front foor opening looking towards the left rear door.
jor
Post by jor »
Here's a couple of photos of the now departed 73 Crew roof. It looks like it's pulled away from the roof panel.
jor
http://home.comcast.net/~oiga/67-13.html
Ford_Doctor
The '73 is braced completely different from the '68, but it does appear that it also has a gap, albeit not as severe.
460 crew
Post by 460 crew »
Mine looked the same way on my 70. It's not like there was any spot welds to join the 2 and there was no way to re bend it to conform to the roof. I think there was a material spacer in mine to begin with that I threw out. So I just put my insulation between the brace and the roof then put up my new headliners in with no problems or noises.
