E40D
coletrain777
E40D
Post by coletrain777 »
Is it possible to swap out the tailshaft on a 4wd E40D to a 2wd tailshaft. I already have the 2wd tailshaft and was just wondering if the swap is possible (done fairly easily). Thanks in advance, you all are awesome. Cole
ezernut9mm
re: E40D
Post by ezernut9mm »
here's what i got from the nloc. link to a thread on the subject:
http://www.nloc.net/vbforum/showthread. ... t=e4od+4x4
68swb
re: E40D
Post by 68swb »
i beleve that the cases are the same so the tail housing will fit just fine but on the 4x4 trans the tail shaft is shorter than one on the 2wd, so you would have to swithch the tail shaft. its not hard if you have torn down a trans. before.
"I got this"
68 swb 429ci 3spd
69 lwb f250 360 4spd
75 VW superbeetle
79 F250 4X4 supercab 400 4spd
07 Fusion
08 Focus 35mpg
coletrain777
re: E40D
thanks for the replies guys. I appreciate it. I guess I will tear it down and get to work. Cole
