OVERDRIVE
btgold29
re: OVERDRIVE
Post by btgold29 »
well the nv4500 is good,
but i was able to get my hands on a tremec TKO 3550 five speed with a pro 5.0 shifter, and GM 26 spline input shaft, and thats what i have behind my 466 big block ford with iron bell housing.
check out www.fortesparts.com you'll love it
they cater to mustang stuff but Mike the owner really knows his stuff. they even made a hydraulic clutch set up for 429/460.
68-f100, 466 ci, tremec five speed, strange rear end, 35 spline axles, 542 hp 535 lbs torque @ the fly wheel. hand built custom headers.
averagef250
Post by averagef250 »
The NV4500 and tremec are apples and oranges. The NV4500 is not a car transmission and does not shift like it. However, the NV4500 will do day in day out for 500,000 miles what the tremec would not last a day doing.
Buy a tremec to drag race, buy an NV4500 or a GV to tow heavy stuff with.
btgold29
re: OVERDRIVE
Post by btgold29 »
I will agree with that,
i was just mentioning another option
but i dont use this truck for work any more
325hotford
Post by 325hotford »
I have a buddy with a g.v. behind a 7.3 with a Banks turbo system in a 10k = lb rv and it works great. You got a hell of a deal. Good luck.
jbanks
Re: re: OVERDRIVE
Post by jbanks »
Can you put a TKO 3550 behind a FE? I don't do a lot of hauling, I'm working on a daily driver. It was my understanding that the TKO 500 and 600 would adapt but not the 3550.
btgold29 wrote:well the nv4500 is good,
