Driveshaft question
AustinTom
Driveshaft question
Post by AustinTom »
Will the 2 piece driveshaft from a C-6 lwb truck fit one with a np435 or will it need to be altered?
69 F-100 lwb 240 Np435
95 F-150 lwb 4x4
http://s110.photobucket.com/albums/n85/ ... type=local
ICEMAN6166
re: Driveshaft question
Post by ICEMAN6166 »
depends if the c6 has a slip in yoke or a bolt up u joint type on the trans end i believe.as far as i know all the 435s are bolt on shafts.
http://fordtruk.com/forums/album.php?ca ... user_id=26
you can ford a river or stream and get to the other side, if you dodge it you will not, and if you drive a chevy to the levee it will run dry and the music will die.
heres a bolt on type just as the autos are.
REDNECKMOBILE
Post by REDNECKMOBILE »
You'll need a driveshaft that has the slip joint build into it.
the truck that trans came out of had a two piece driveshaft.
390Nut
Post by 390Nut »
You'll need to at least change the yoke, as the C6 had either a slip yoke, or a flat, bolt on yoke, depending on the type of C6 (some had a short shaft tailhousing that has a flat, four bolt flange, more common to the trucks than cars, and some had a slip yoke).
The length will be a factor as well, and will likely need to be cut and have the joint flange rewelded (requiring a rebalance of the driveshaft assembly) or just find the proper driveshaft assembly elsewhere.
Paul
`69 F100 390 4spd driver
