leftover part..... borgwarner t-19 4 speed.
crazy larry
Post by crazy larry »
so my shifter broke. it was disassembled, welded where it needed and then put back together. only i have a part left over. It is a small metal cylinder shaped doodad, about and eighth of an inch thick, by a little more than 3/8th's inch long. I do not remember when it popped out. I do know that i do not have reverse now.... so does anyone have a good diagram of this shifter? sorry i don't have a pic to show, but if needed, i can post one later. :? :hmm: :hmm: :?
thanks,
Larry
'72 F-250 Kustom 396 c.i.
Fotoes
re: leftover part..... borgwarner t-19 4 speed.
The only shop manuals I have right now with diagrams of those are the '67 shop manuals, but they don't show the T-19, only the T18. However, I believe they're close enough for you to get an idea of what they are. Here are two diagrams I just scanned for you.
In this one, you can see the interlock plungers and interlock pin, which look like what you're describing:
The second one was too large to post, so here's a link:
http://www.fordification.com/board/NP43 ... gram02.jpg
Hope this helps...good luck! :D
crazy larry
Keith, you kick ass. :rock: the interlock pin it is. :hd:
I hate it when parts fly out faster than i can recognize where it came from. :cuss:
you just got you a donation. :2cents::thup:
and :fte:
Larry
Fotoes
crazy larry
:yt: I'm not sure i said thank you.?
Larry
Fotoes
You're welcome....glad I was able to help. (and thanks for the donation! It's greatly appreciated! ) :D
