Clutch Rebuild
ScottVA
Clutch Rebuild
Post by ScottVA »
I am new this is my first post. I need help, I am a novice mechanic, I can accomplish most simple mechanical stuff, changing alternators, etc...
What I really need is a HOW TO for a clutch rebuild for a 1971 Ford F100 truck with a 360 engine.
and More I would really like to find a good Book on, rebuilding and restoring my truck. If any one can point me in the right direction I would greatly appreciate it...
to replace the clutch you must remove the transmission and the bellhousing. then you remove the pressure polate and clutch disc. you can also replace the flywheel at the same time if it is bad. putting it back together you will want to use a clutch lineup tool. this make reinstallation of the transmission easier because it has to go itno the clutch disc and the pilot bearing at the same time.
that is the basics of replacing one.
book: chilton has them haynes makes one factory books can sometimes be found on ebay as well as the book on cd. there is a guy name steve ____ that wrote a book on rebuilding the fe engines also.
ScottVA
re: Clutch Rebuild
Post by ScottVA »
Excellent thank you... Can you recommend good location to purchase parts for my truck 71 ford f100 w/ a 360 Again thanks for the quick response
lightning_msd
re: Clutch Rebuild
Post by lightning_msd »
online or over the phone ones are good, but i live in canada so i dont know what to tell you what stores to go to,
Ebay sometimes has stuff to you may get a great deal on
www.lmctruck.com
http://www.npdlink.com/
www.blueovaltruckparts.com
good luck and happy new year! :fr:
ScottVA
re: Clutch Rebuild
Post by ScottVA »
again thanks alot...
your local parts store would be a good start as to where to look for parts.
jor
re: Clutch Rebuild
Post by jor »
The book fordman was referring to is How to Build Ford Big Block Engines by Steve Christ. You can get it at Barnes & Noble or online at Amazon. I think it's 20 bucks or so. It is an excellent resource for your engine work and it touches upon the clutch.
jor
