MT shift knob
- lightning_msd
re: MT shift knob
its not??? it is pretty sloppy shifting, in 1st and staying in first i can make it look like its in reverse i was wondering if maybe its posible that it was reinstalled backwards, i have looked at some other t18 shifters and it looks like the elbow points towards the seat and not the dash panel.
maybe the shifter is out of something else. to remove the shift from the some top shifting transmissions. there is a metal slevee you can push down and turn couterclockwise i think to remove the shifter from the trans. you could pull it out and look to se if you can turn it around. i have no idea but i kind of think you might not be able to.
- averagef250
You likely just have a worn out top plate or shifter. The T-18/19's use a single locating pin to keep the shifter from spinning while most everything else has 2 pins. When you pull the shifter out, check to see what shape this pin is in, it's probably widdled down to a sliver. The best fix is to find a better top plate. Just replace the whole shooting match and you won't have to worry about it.
- FLATBEDFORD
I replaced that locating pin in mine. It was widdled down to a sliver allright. I cut a piece of drill bit shank to the right length. I figured that was the hardest stuff I had handy.
My Photo Gallery
My Photo Gallery
re: MT shift knob
Yup, weld the hole up. ReDrill. Make new pin. Weld up groove in the
ball. Re-cut. Done it. Lasts a couple years. Gets loose again.
Next time I re-do it. I will put a pin on the other side too and cut a groove
in the ball.
in the ball.
- lightning_msd
re: MT shift knob
hows about i just rip the whole f*^()( tranny out blow it up and put in a c6
- averagef250
Pull your floor mat out, pull the tunnel cover off, pull the whole top plate off and put a new one on. It takes a 1/2 hour. Last time I bought just a top plate it was $20 from a wrecking yard for a 435. The 1-2 shift fork snapped off in the 435 that used to be in my '70. I was about 20 miles from civilization and 50 miles from the nearest wrecking yard. I pulled the top plate and shifted the gears with a screw driver. Drove it all the way there, gear oil everywhere, put the new top plate on in the yard parking lot and went back out in the woods.
