quick trans question
- boots
i have a np435 from my 68 f250 (divorced t-case and all), and want to put it in my 2wd 67, which has a 3 spd right now... its just bolt in right?
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- two-bit
re: quick trans question
I believe so, except for the hole you have to cut in the floor for the shifter on the NP435.
- heep70
Different bell maybe. Call the auto store to see if there is a different pressure plate and disk. I do believe you will run into length issues. The 435 that come out of 4x4 have the short output shafts.
There are 435 trannys that have the long tail shaft for 2wd applications.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- boots
I have the bellhousing too, so it will work?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
