going from the floor back to the column
chips68
Post by chips68 »
I have a 68 f100 3spd orginally on the column, a past owner cut a hole in the floor and put in a floor shifter which works fine, but I want to go back orginal. All the parts to the column shifter appear to be there, including the linkage (which rattles against the exaust pipe). The column shifter however has problems, it will move up and down (towards the floor and roof) but won't move back and forth (toward the firewall and steering wheel). What is the diffuculty level of rebuilding it and would it be expensive. And I don't know but I would imagine its just some bearings and bushings? Any knowledge on this would be appreciated
the shifter arm is probably boke or worn getting that part will be the hardest thing you will have to do in rebuilding the column.
Jake11
re: going from the floor back to the column
Post by Jake11 »
It's probably more trouble than its worth. There not all that hard to work
on other than pulling the T/S switch. The parts might be kinda hard to
find. The shift bowls at the top always break where the lever goes in.
They like to get stuck in second too. I had one and liked it, but got fed
up with it and put in a floor shifter.
jhannahokla
Post by jhannahokla »
i moved mine to the floor collum shift worked fine when it was warm out side but when it was cold it didn't want to come out of neutral for nothing so i wound up breaking it takeing it apart to fix it the shift tube is broke on mine
James
1970 F-100/302/3spd/9 Inc RearEnd 3.50 G/R
Image Watch This BurnOut !
trukcrazy
Post by trukcrazy »
I would go to the trouble if you want the column shift. That will be the most unusual feature of your truck. I had guys at Walmart tire and lube not able to pull my truck into the bay because they had never seen a 3 speed on the column. Fix it and that will be daring to be different! :lol: :lol:
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
flyboy2610
Re: re: going from the floor back to the column
Post by flyboy2610 »
trukcrazy wrote: I had guys at Walmart tire and lube not able to pull my truck into the bay because they had never seen a 3 speed on the column.
:lol: :lol: :lol:
bobbyinpd
Post by bobbyinpd »
trukcrazy wrote:I would go to the trouble if you want the column shift. That will be the most unusual feature of your truck. I had guys at Walmart tire and lube not able to pull my truck into the bay because they had never seen a 3 speed on the column. Fix it and that will be daring to be different! :lol: :lol:
Sounds like UTI's Finest to me!!!!
1996 F350 4 Door Dually Long Bed Power Stroke Diesel - K&N FIPK Intake, MBRP 4" Straight Exhaust, Diesel Turbo Lifesaver Turbo Timer, BriteBox.
1990 Escort 1.9L Stock
1958 Bel Air 4 door - FOR SALE
1975ish Camaro Autocross Car
1973 Camaro RS awaiting cage,backhalf, and 498 BBC
1969 El Camino - Wife's car
2004 Carson Trailer-to haul the goods!
www.bobby77.com
studdmstr
Post by studdmstr »
Not to hijack the thread, but I want to do the same thing as chips68.... go back to the column shifter. Anyone know where I can get the pin to attach the shift lever to the shift collar on the column?
it a regular roll pin. the partrs store has them.
