Need some C6 tranny help
dropper
Post by dropper »
I searched but if I missed it I'm sorry.
Here's the deal, I just pulled a C6 from a 79 econoline with a 302.
To put into my 72 F100 with a 302 and a C4.
It looks like the C6 is about a foot longer than the C4, and the yoke is different.
Is this going to be do able?
Has anyone attempted this?
I have 14 days from 10-29-06 to make it work or take it back.
Any help would sure be appreciated.
By the way I love the site. I've been lurking around here since I got the truck about a month ago.
it will fit. you will need a different driveshaft though.
dropper
re: Need some C6 tranny help
Post by dropper »
Thanks Fordman for the quick reply.
I am pulling the C4 now.
I'll post up my adventures for others as I go.
Clarko
Post by Clarko »
Use the flexplate from the Econoline. You may also need to move your crossmember back on the frame. Can you grab the yoke off the Econoline, too?
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
dropper
Post by dropper »
hey Clarko, thanks for the reply.
Yeah I realised I'm going to have to go back to get the yoke.
I'm also going to pick up another drive shaft from a F100 to shorten. Just in case I have to go back to the C4 set up I will the original. You think I should grab the flexplate too? Why is that?
Update: The C4 is out, it took me twice as long to pull the C4 than it did the C6.
Couple of things it looks like I'm going to have to do is drill the frame to move the crossmember back. Also the mounts are different I will have to drill the crossmember to attach the new mount.
Thanks for the help
1972 F100 302
1992 Ranger 3.0
1996 Jeep Cherokee 4 inch lift on 33's
2000 Explorer 5.0
Clarko
Post by Clarko »
The C6 flexplate is larger than the C4 one. Also, the starter should be the same but it wouldn't hurt to grab the C6 one.
Brian
dropper
Post by dropper »
Bolted up the tranny last no major issues. Now for the fun part fabrication: lines, driveshaft, and linkage. I just hope the tranny is good!
1972 F100 302
1992 Ranger 3.0
2000 Explorer 5.0
Big D's 69
Post by Big D's 69 »
Glad to hear it is all working out for you. Keep us posted.
dropper
Post by dropper »
Got a question.
Should I cut my driveshaft if I do it will make it about 25 inches from end to end. Or should I go with a one piece from another vehicle and cut it to fit?
Thanks
1972 F100 302
1992 Ranger 3.0
2000 Explorer 5.0
making a drive shaft should be done by those who usally do it. they have to be balanced and the flanges ahve to be put on oppisite of each other. is that measurement from center of flange to center of flange?
dropper
Post by dropper »
Thanks Fordman for the reply,
I was wondering if I should keep the two piece set up or go with just one drive shaft. After the smaller drive shaft is cut it is seems really short, only 25 inches from splines to flange.
I wasn't planning on building the shaft myself. There is a machine shop where my dad works they will be welding and balancing. I do have to get all the measurements and find out what will work best though, as they are not auto mechanics just machinist.
Thanks for the help.
1972 F100 302
1992 Ranger 3.0
2000 Explorer 5.0
Clarko
Post by Clarko »
Do you have a long bed or a short bed?
Brian
dropper
Post by dropper »
Its a long bed
1972 F100 302
1992 Ranger 3.0
2000 Explorer 5.0
Clarko
Post by Clarko »
I think you would like to keep the two-piece than.
Brian
flyboy2610
Post by flyboy2610 »
Yea, keep the two piece shaft. A one piece shaft long enough to fit your truck would be very sensitive to imbalance.
