Thinking of buying '69 F250 4x4 ... wadya think
A place for new members to introduce themselves
lbhgti
Post by lbhgti »
I've been a chevy man all my life, and then I got tired of replacing transmissions. My current tow vehicle is a 05 tacoma, which does OK but I need a bigger truck. I turned wrenches for toyota for a few years and I like their product. Anyway, a buddy came by the shop the other day with a '69 F250 4x4, 360 4spd with 37"s on wagon wheels, and it looked pretty stout. I thought to myself...maybe I'll try a Ford. Its got some rot on the front lip of the hood, and a bit at the bottom of the doors, but otherwise it looked solid. Its got saddle tanks too. The paint sucks but the body is straight. I can pick it up for about $1200....and its' got a fresh motor in it as of about 2 years ago. I'd be piling about 800lbs of crap in the back and towing a 4000lb trailer, with trailer brakes. The truck won't be my daily driver, but more of a once a week hauler. I've been reading these forums the last couple of days and I need some clarification on a couple of things. I assume that this rig has the NP gearbox and Dana 60 axles. Am I right? Also, this is a 4 wheel manual drum brake truck. I know I can convert to power relatively easily, but how hard is it to convert to front discs.....or will the front drums be OK towing a trailer. Is there anything else major I need to look for on the truck before I throw down the cash? How will a 360 do towing....I've noticed that their isn't the performance parts selection for the FE motors like the 351s and 460s, but a swap isn't a problem...after all, I'm a mechanic.
Blue Cloud
re: Thinking of buying '69 F250 4x4 ... wadya think
Post by Blue Cloud »
Buy it, put a 460 in it, some LT238/85R16 tires on it and you'll never want a cheby again. :lol:
Blue Cloud
oops! LT235/85R16 tires :oops: :lol:
lbhgti
Post by lbhgti »
How do the 360s run....
72hiboy4x4
Post by 72hiboy4x4 »
the way I hear it:
360 will out torque a 390, but the 390 will beat on HP.
the 360 is a good truck engine ie: low speed grunt and power to pull a house down. Just not the fastest thing you've ever driven.
390 will get you there faster and probably a little more enjoyable driving.
FWIW. I have a 360 in my truck now, and it pulls trees out by the roots (evidence in the front yard as we speak).
Eventually it will get replaced by a 390, cause I wanna use it in competition mud runs once in a while.
I don't think you will go wrong at that price at all. Get it and be happy forever.
as for the axles, it should have a Dana 44 front and a Dana 60 rear stock. Power drum brakes will do you just fine, they have been stopping my truck for the 8 years I've had it, and it used to pull the 16' car trailer.
With 37" tires, I'd make sure the gearing is where you want it, or it will take away your towing capacity. I'd guess in the way low 4's or hi 5's (like 5:38's)should be good.
Clarko
Re: re: Thinking of buying '69 F250 4x4 ... wadya think
Post by Clarko »
I wish I could have found a 4x4 when I was looking.
GET IT!
Blue Cloud wrote:oops! LT235/85R16 tires :oops: :lol:
I bet the truck's lifted. Way too small for this truck. 235-85s are great for 2WDs though.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
Brett6269
Post by Brett6269 »
Welcome, the nice thing about older trucks is ya can modify, to the moon ,and not have to worry about the emission man, at inspection time!! brett :wel: :fr:
lover of old fords
460 crew
Post by 460 crew »
I think it was meant to be for you and you should pick it up and never look back. Fords are tough trucks and a 4x4 to boot. Like 72Hiboy said check out the rear axle tag and make sure it's at least a set of 4.10's or higher because of those 37's you'll get some nice mileage on the Cali freeways and takeoffs should be ok still with a 435 granny 1st. A stock 360 should pull your load with ease. my experience is the fe's like to make bottom end and mid power but the upper valvetrain doesn't like polonged top end abuse or you can follow along behind with a milk crate to gather your spare parts. So I vote s yes even if you need to make a gear changed down the road if it doesn't work perfect for you. :thup:
lazyj70
Post by lazyj70 »
Get a FORD! NOW!
2008 F-350 Lariat Crew Cab 4X4 Western Hauler
1970 F-100 Ranger XLT.
flyboy2610
Post by flyboy2610 »
Welocme aboard! Definitely get the truck!
CJ,s 67 F100
Post by CJ,s 67 F100 »
That 360 will do the job you want it to do just fine and the front drums will be fine as well for your week end hauler with 800 in the bed and a 4k trailer. If you need more power just drop your tire size to the original specs. The upgrades are fun (390 and discs) but not needed. Good luck with it and welcome aboard
foghorn
Post by foghorn »
Well ill be the first okie to say yo and :wel: also you already know that :fr:
foggy :D
hossw71SportC.
Post by hossw71SportC. »
Go for it man.
oh and :wel:
Get-R-Done
71 F100 Sport Custom
99 F250 Powerstroke
71 LONG BED
Post by 71 LONG BED »
$1200? Your crazy if you let it go. After you buy it you'll have a great suport group to help out with all your questions. :thup:
John Member #1549
Image Image Image
Dropped 68
Post by Dropped 68 »
Welcome!
