Stupid Question
derek7871
Stupid Question
Post by derek7871 »
On my '68 F100 with the 3 on the tree w/overdrive, do I pull the lever out or push it in to engage the overdrive?
72hiboy4x4
re: Stupid Question
Post by 72hiboy4x4 »
whichever way makes the RPM's drop when you are going down the road.
Never had one, so I cant help more than that.
68F250
re: Stupid Question
Post by 68F250 »
From the '68 owner's manual
Barry
foghorn
re: Stupid Question
Post by foghorn »
The only dumb question is the one ya dont ask
foggy :D
derek7871
re: Stupid Question
Post by derek7871 »
When my dad gave me the truck, he told me the overdrive slips out of gear and not to mess with it. Well, I left it alone for several months.....until three days ago. I engaged it and after 3 or 4 miles it slipped. It was just like if you pushed in the clutch and gave it some gas. Anyway, now I think the OD is still engaged and I can't get it to disengage. This morning, I tried to drive it to work and it was slipping again. I was trying to move the OD handle and apparently the cable broke. So now I guess I have to manually disengage the OD unit. Just when I finally had everything working good, I had to go messing with the stupid OD!! :x
cathynkeith
re: Stupid Question
Post by cathynkeith »
Always listen to Dad, I learned this years ago when I was 28 (too late)
now I'm 38 and dad is 74 now I listen and listen and listen and listen and :dk:
Listen now and lear while you can. It will not be long until your the man.
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
Jake11
re: Stupid Question
Post by Jake11 »
There ain't no "stupid questions"
Hang it out there and see what you get. Don't ever feel like it's a stupid
question. Everybody here is pretty helpfull and their good guys.
8)
