3.03 trans swap for a 4 speed
71 LONG BED
Post by 71 LONG BED »
I hope this doesn't sound like to much of a dumb question.
I want to replace my 3.03 trans with a 4 speed. Is there one that is easier to swap in than the others?
I need to do something soon because second gear is getting pretty loud lately. I don't want to make it a huge wallet draining project, though. If there is nothing easy than I will just rebuild my 3.03. Thanks, John.
John Member #1549
Image Image Image
jzjames
Post by jzjames »
3.03 would be your rearrend differential gearing?? Transmission would probably be easier to just swap in a good one.
splavin90
Post by splavin90 »
he's talking about the ford 3.03 three speed transmission. it's a 3spd manual.
what engine do you have?
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
jzjames
Post by jzjames »
Had to be. First time Ive heard of the 3.03 Ford trannsmission.
71 LONG BED
splavin90 wrote:what engine do you have?
I have a 302.
John Member #1549
Image Image Image
71 LONG BED
jzjames wrote:Had to be. First time Ive heard of the 3.03 Ford trannsmission.
It is the Ford light duty 3 speed column shift. :D
John Member #1549
Image Image Image
72hiboy4x4
Post by 72hiboy4x4 »
I pulled one out of a '71 years ago, and installed a NP435 as a direct bolt-in. didn't change anything but the tranny.
EDIT: mine was converted to a floor shift previously. you may have to change the floor tunnel pan to get the access hole.
splavin90
Post by splavin90 »
yeah, ditch the 3.03 sell it to somebody.
get an NP435 and you'll have yourself a sweet truck 8)
a friend of mine has np435's in his trucks, and man they're awesome in 1st gear. 4x4 low and in 1st gear and you can do anything. even with his emmisions equiped 300
71 LONG BED
NP435 it is. Now I know what to keep an eye open for. Thanks a lot guys. :D
John Member #1549
Image Image Image
FoMoCo
re: 3.03 trans swap for a 4 speed
Post by FoMoCo »
I swapped my 3.03 for what I beleive to be a TOD. It's a small aluminum housed 4spd over drive. The mounts, bolt up, and drive shaft are all direct swap. These came behind early 80's f-100's mostly with inline 6's.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
