Debating 700R behind FE
kid
Post by kid »
Autozone.com for my 89 GMC a TH400 is 580+300 core and a 700R is 892 +325 core.
Clarko
Post by Clarko »
Just go for the AOD. There is no vacuum modulator so you can do anything to your motor without worrying about it at all.
My buddy has a 700 hp 66 mustang with a built AOD to handle it all and the trans was about $1200 including a new T/C and core charge.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
binder56jd
re: Debating 700R behind FE
Post by binder56jd »
now serving #235
pat67shorty
Post by pat67shorty »
AODs blow... (litterally) Unless you invest 1k into them in new hard parts. The 700R4 is a bit more stout in stock form... but if you want either to last behind somehting that makes torque... you will need to have it built.
Unless you need or want the lower 1rst gear of the 700R4... I'd go with the built AOD. You're gonna be spending $2500 with either one anyway...
Oh yeah... SHIFT KIT. SHIFT KIT. SHIFT KIT. Soft shifts kill trannies.
'67 SWB, 1970 car 390, Edelbrock Streetmaster intake, MSD 6AL, 780 Holley, Hedman headers, 2.5 duals, 3.54 D44 L/S, C6.
customcrewcab
Post by customcrewcab »
72hiboy4x4
Post by 72hiboy4x4 »
uumm...thats an underdrive unit. don't think thats what he wants (unless I'm wrong. thats been known to happen! :lol:)
kid
Post by kid »
Put the underdrive (P.S. you are right it is)on backwards and you have an overdrive :hmm:
willowbilly3
Post by willowbilly3 »
Forgive me for skiimming and maybe repeating someone else. I think a built 700R-4 would be a better choice that a Ford AOD. The AODs have lots of problems and they cost more to build. Plus I think the Ch**y tranny has a lower first gear.
Clarko
Post by Clarko »
Ya know, if ya have the cash, build up an E4OD. They came stock behind all 7.3 Powerstrokes and hold up to a lot of power if built correctly.
Brian
gonzalo medina
Post by gonzalo medina »
Ok guys I finally contacted the gear vendor dealers and they quoted me 2,659 dollars not including shipping. These guys are seriosly druck :$$: I want overdrive but at that cost I could just put a down payment on a motorcycle. I was told there is a few manual transmission that has overdrive and will bolt up to the FE's. The only ones I know of are the toploaders and T18/T19's, can any one clear this up for me. I don't mind swapping over to manual if it will help gas and performance.
67highboy
Post by 67highboy »
I say put the AOD in there..
:D
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
Leadfoot
Post by Leadfoot »
:hmm: for the price of your trans, I would look at a 300 six and a C6, for like $1000.00. ya its not a V-8 or a big block but if your trying for fuel milage why play the big block FE game your just going to end up spending to much and getting #*%& out of it. :2cents:
WHAT ?
67highboy
Post by 67highboy »
:yt: If your going for fuel milage you won't get much better than a 300 in these old trucks.. :2cents:
Ben Franklin 1775
willowbilly3
I say go with the built 700R4. I think the aod is junk. They are extremely expensive to build. Generally expect $1400-$1800 just for a stock rebuild of your tranny. You can get a built 700R4 straight away for a lot less. Plus the ratios and shift points on the 700 are more favorable. Last I knew you could not hold an aod in any gear past about 4400 rpms. Maybe a modified one.
Another annoyance of the AOD is the delay when you shift it into gear. Every time I get in one (we have about 10) I drop it in and press the gas, only to realize it has hit about 2500 before the stupid thing has had time to take it's leisure getting into gear.Annoying
Clarko
Post by Clarko »
willowbilly3 wrote:I say go with the built 700R4. I think the aod is junk. They are extremely expensive to build. Generally expect $1400-$1800 just for a stock rebuild of your tranny. You can get a built 700R4 straight away for a lot less. Plus the ratios and shift points on the 700 are more favorable. Last I knew you could not hold an aod in any gear past about 4400 rpms. Maybe a modified one.
You have one messed up AOD my friend. My AOD in my Bronco shifts about 1900 at the latest. Also I have revved my AOD past 4500 before with no ill effects. And mine is behind a motor Ford never dared to put an AOD behind in a truck, a 351W and not just a fully stock one but I have all the normal mods I can get away with here in CA. My AOD has never been rebuilt and I am at 150K now.
To rebuild my AOD with a deep pan, better bands/clutches, shift kit, etc. with them removing/installing it in my truck was $1100 out the door. And mine's more of a PITA since it's 4x4.
Brian
