Debating 700R behind FE
gonzalo medina
Post by gonzalo medina »
Ok guys I have been running this idea through my head for months now i finaly need to step up or shut up. I have the source to the adapters and have heard all the chevy put downs. Will this tranny run good with my engine???? Alot of chevy buys say I will never go back to the c6. I need advice seriously because this will be a 2000 dollar investment.
ToughOldFord
re: Debating 700R behind FE
Post by ToughOldFord »
Those same Chevy guys are used to riding around in other peoples cars and trucks.
prostreetf100
Post by prostreetf100 »
i personally would go for the ford aod. seen to many dead 700's compared to aod's. you can get them with a bellhousing for the fe engine or buy an adapter for it.
72hiboy4x4
Post by 72hiboy4x4 »
here's some reading for ya here.
http://www.redrider.us/
I personally have bought one of the Raptor JR trannys from these guys, and it was top quality. replaced my dead 700r4 in my Camaro, and was a definate improvement over stock!
don't know much about the FE conversion, but I know their tranny held up fine to my 350/300 hp engine.
prostreetf100
this place has an adapter for the aod to fe http://www.transmissionadapters.com/ford_fe.htm performance automatics builds aod with a different bellhousing to bolt directly to an fe engine. their web site is performanceautomatic.com the aod transmissions can be built to handle a lot of power. a friend has one in his car that makes over 600 horse power at the tires in his 95 cobra. has been in the car for quite a few years now.
kid
Re: Debating 700R behind FE
Post by kid »
gonzalo medina wrote:Ok guys I have been running this idea through my head for months now i finaly need to step up or shut up. I have the source to the adapters and have heard all the chevy put downs. Will this tranny run good with my engine???? Alot of chevy buys say I will never go back to the c6. I need advice seriously because this will be a 2000 dollar investment.
GM has been in class action law suits over All of the auotmatics after the Powergrunt. The suits are still going on. My 89 GMC r35 Boom truck has a TH400 the forerunner to the 700 and the Low and reverse planetary exploded. Well the 700 uses the same parts for power transmission.
Some of you have seen my notes about a TH400 I built but that was to solve a problem with a 750HP 396 69 Gymkana SS Camaro I built until my scattersheild came in to hold a Ford 10bolt toploader to the 396.
Every race with that TH400 was a nightmare waiting to happen.
C6s were real tough and until Chrysler got their racing automatics fixed there was an adapter to put C6s behind Hemis.
gonzalo medina
Ok so the 700r is out of the picture aod is the way to go. All in favor say I and the teardown begains. I really would like to punch my fe and have it respond with confidence. What kid of drive shaft mods will apply to this set up?????? I am really serious about this.
72hiboy4x4
so.....what tranny are you going to use again??
I'm confuzeded :hmm:
never mind, my addled brain was reading aod as 'and'.
I say go for it! But would have been neat to see the 700r4 behind the FE
kid
Post by kid »
Aye
kid
Post by kid »
Aye again
customcrewcab
Post by customcrewcab »
why do you waht the 700r4? for the overdrive? if your going to spend 2000 just get a gearvender. why have a 4 speed when you can have 6. plus c6 are really strong.
gonzalo medina
Well I ran a price check on the 700R today. They quoted me 800 without coverter so I rounded off to 1000 plus the adapters another 700 which brings the grand total to 1800 to 2000 tops. The gear venders I have seen range from 3-4 grand. you tell me.
customcrewcab
3 to 4 grand? i think the most i have seen it 2500.maybe that install price. i would look for a used one first. they don't go bad and handle like 1500hp. what happens if the 700 blows up. i hsve had stuff like that happen and found maybe its better to spend a little more. i agree 3000 to 4000 is too much. i'll find out what we can get them for. a mustang we did had one behind an aod.
gonzalo medina
If you could get me some links to those gear venders I sure would like to research them. I just can't stand the c6 gearing. I have even considered running a 4 speed toploader. The key here is being conservitive. Thanks in advance.
customcrewcab
how about a t-56. the standard one is 1900, viper spec 3000. i am not sure about the fe but i know the have a bellhousing for 460. comes with shitfer bellhousing and yoke.
