F250 front disk brakes
snake
Post by snake »
Do the 3/4 ton front disk brakes utilize a one-piece hub rotor assembly or is the rotor separate??
Can anyone identify if any vehicle utilized a separate rotor for 8-lug application?? (front or rear)
thanks
willowbilly3
re: F250 front disk brakes
Post by willowbilly3 »
Most are one piece I believe. There are a couple different styles. The single piston is the one parts cost less for and easier to work on. I had the dual piston ones on my 72 and they worked real well but ate pads bad and needed frequent attention due to the sliders freezing up.
mcarlson11
Post by mcarlson11 »
the 3/4 ton are a 1 piece hub/rotor.
When the going gets tough, your doing something right.
