Some of the trim on my '72, like the grill is call "bright aluminum". Is that some kind of electroplating or anodizing?.
The reason I ask is because the my grill got damaged in the middle. I found one pick-a-part that is good in the middle but rough by the headlights. I was thinking of trying to patch weld in the good part and then having the whole thing chromed, if that is what it is.
Any thoughts on this?
Thanks
what is "bright aluminum"
re: what is "bright aluminum"
"Bright aluminum" simply means polished aluminum that is then anodized for protection from the elements.
As for welding that.....man, I hope whoever's going it is a true professional, as sectioning a thin piece of aluminum (and in multiple places!) like that and making it seamless will be next to impossible to do. There will definitely be a HUGE amount of manhours involved, not only with the welding, but then the necessary polishing afterwards to completely blend all seams.
I might be wrong, but I think you're going to have a lot more money invested into it than you'd have spent just getting yourself a good straight replacement grille.....and I think if your intent is to chrome-plate a grille, I'd suggest keeping your eyes open for a good steel grille and plating that, instead of the aluminum version. It'll be a lot more sturdy and any necessary repairs before the plating will be MUCH easier.
Just my
Just my
I don't think there is a steel grill for the 72, so he'd need a 67-69, and all the parts to swap it over.
NPD, Carpenter's, etc all carry new grill shells, but they are pricey.
- lazyj70
Also the tread bright is hard to keep to a mirror finish. Once dirt hits it it's pretty much dulled.
2008 F-350 Lariat Crew Cab 4X4 Western Hauler
1970 F-100 Ranger XLT.
I found a steel 68 grille in a junkyard.It had a dent in the top bar and a crease on the side where the turn signal marker light.I stripped all the parts off it.I sent it to a chromer and they fixed all the dents.But at a price of $1500.00.When I got it back it looked brand new.I got some nos headlight doors off of ebay and had them chromed too.The results where great.
