Can someone help me with the axle size (dia) and spline for the Dana 60 rearends??
I don't suppose it would happen to be the same as the Ford 9" 31 spline axles would it??
Thanks!
Dana 60 axle spline?
- snake
re: Dana 60 axle spline?
not sure on the diameter or spline, but i do know the dana 60 is a full floating axel and the 9" is not. the full floating axel has either 8 nuts&studs or 8 bolts (depending on the year) holding the axel in.the 9" dosen't.
- pat67shorty
- heep70
The D60s from our rigs are only 16 spline and the newer Ford bought Danas are 30 spline.
The 16 spline has a 1.18" shaft and at the splines it is 1.30".
I believe the 30 splines are 1.5"
Pat67shorty. I am not for sure but I don't think Ford did 35 spline unless it was above a F350 or special order. I know the military chevies are all 35 splines in the front.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
